I can't find why the webcam stream is not instantly loading on my Windows 10 PC (1min10s)
It's fine on my iPhone and my Macbook.
I've tried to disable hardware acceleration, install the windows media pack, update my k-lite codecs, change my web browser (chrome,firefox, ie11, opera) in vain.
Any idea ?
Thanks for your quick reply.
It takes 1min10 second to display the video.
What's the url for the video ? I've tried http://myip:8080/?action=stream without sucess
That URL should be ok.
Have you checked the path to FFMPEG. This is usually /usr/bin/avconv.
it works in VLC but it takes 2min30 to load
So some additional questions:
Do you use a Raspberry Pi and what version?
Do you use WiFi or LAN connection?
How fast is the SD card you use?
If you use WiFi, I almost assume the WiFi channel you use is also used by another router in your neighbourhood. That can reduce the connection speed very much.
Perhaps you misread but it's working fine on my Apple's device. The stream starts immediately.
I use a Raspberry Pi 2 on a wired connection. The SD Card is a class 10 U3.
It seems that in windows 10 it needs to buffer a lot (2min30) and then display the feed...
Well, it's not expected to be compatible with IE since it doesn't support using an image tag with a video.
Actually Iβm using Firefox not IE11
I am experiencing this exact issue. Webcam stream loads instantly both on my Macbook Pro and on my iPhone via the Octopod app. When I pull it up on my Windows PC in Chrome, the stream takes more than a minute to load.
Has anyone found a solution?
I have the same issue with my Logitech C270. Working flawlessly on my Androids Octoprint Apps, but takes 1min + in Windows Chromium. Annoying black vodoo. I suspect the nginx proxy wrecks things up, but I have not found a solution (and will not further investigate the issue)
Any progress with this as I have been fighting this for a while. My Android devices work perfectly but Windows 11 is taking more than a minute. I also use Obico self server and it works in Windows so using it as a work around until a solution can be found. Tried Firefox, Chrome, and IE but all take over minute to load.
