Hi
I was trying to bump up the resolution of my RpiV2 to get a 4:3 instead of the 16:9 to have a better view on my printbed. Unfortunately if I change the resolution from 1640x922 to 1640x1232 the webcam stream remains "loading". Also the 8080/stream doesn't show an image anymore.
Since I thought it might be a bandwidth issue i changed the framerate to 1 but this didn't help.
The used resolution are the ones from here 6. Camera Hardware β Picamera 1.12 documentation
Also the log shows somewhat other settings than I set in the octopi.txt
I have some programming background but know nothing of Rpis so far
I read similar topics but not about the exact same setup, so I though I give it a try
Rpi V2
Stream not loading at r upwards of 1640x922
decreasing the framerate to 1
Logs (/var/log/webcamd.log, syslog, dmesg, ... no logs, no support
octopi.txt:
camera="auto"
camera_usb_options="-r 1640x1232 -f 1"
camera_http_webroot="./www"
camera_http_options=""
log:
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 1640x922 -f 5
raspi options: -fps 10
http options: -w ./www
RPi4 4Gb via Wifi
I accidentally typed 1460x1232 while trying around and for some reason this works.
I also found that it works up to 1525x1232.
When I try to change any camera settings in octolapse:
"Error Applying Webcam Settings
Status: error. Error: INTERNAL SERVER ERROR"
