ipCam (iOS)
Stream doesn't work in Edge browser. Snapshot works. Stream works in OctoEverywhere, FireFox, Chrome, Opera and OctoApp on android.
EDIT Also NOT working in OrcaSlicer
I am using an ip webcam using ipCam app on iOS. I can access the mainpage which gives links to video and snapshot links. The addresses follow:
ip.address.on.ios:port - this is the main page
ip.address.on.ios:port/image.jpg - this gives a snapshot
ip.address.on.ios:port/video.mjpg - this provides video feed
I can access each link on both host and local machine (host - what octoprint is running on, local - another pc on local network). Octoprint works on both machines.
Allowed ports on all devices involved, tried several different ports. Tried to find information on why Edge doesnt like the stream via octoprint, but has no problem opening it in its own tab.
Yes
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36 Edg/119.0.0.0
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 8
env.hardware.freq: 3400.0
env.hardware.ram: 8252194816
env.os.bits: 64
env.os.id: linux
env.os.platform: linux
env.python.pip: 23.3.1
env.python.version: 3.10.12
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.3
systeminfo.generated: 2023-12-04T23:20:57Z
systeminfo.generator: zipapi
Octorprint running on LinuxMint on MS Surface device. IP Cam thru app on iPhone. My default browser is Edge (please dont bully me). The obvious answer is "just use a different browser", but I do find this interaction curious. The only part of the equation which doesnt work is viewing the stream in octoprint in edge browser, everything else works.
