Webcam using mac mini
Logitech
Connecting to the stream
Trying adresses combitions
Hello
I have been trying to setup OctoPrint on an old mac mini I am using as server pc. Octoprint on its own works fine but I struggle with adding webcam stream. When I use following ffmpeg command:
ffmpeg -f avfoundation -framerate 30 -video_size 640x480 -i "0:none" out.avi
out.avi file looks just fine but when I try to stream it using the following command:
ffmpeg -f avfoundation -framerate 30 -video_size 640x480 -i "0:none" -vcodec libx264 -preset ultrafast -tune zerolatency -pix_fmt yuv422p -f mpegts udp://localhost:12345
I have no idea how to connect this stream to Octoprint. I did not manage to view it in VLC either. I know it is running based on the terminal output.
Any suggestions and advice are welcome.
