BWWNBY Webcam
Webcam was working, but I haven't used the system in perhaps 6 months. Powered it up and everything but the webcam is working in Octoprint. Octoprint reports "Webcam stream not loaded"
Reading. Since this had been working, I'm unsure where to start.
/var/log/webcamd.log doesn't exist
dmesg has this:
[ 1566.429103] usb 4-1: USB disconnect, device number 2
[ 1575.165372] usb 4-1: new high-speed USB device number 3 using ehci-platform
[ 1575.323291] usb 4-1: New USB device found, idVendor=05a3, idProduct=9331, bcdDevice= 1.04
[ 1575.323339] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1575.323362] usb 4-1: Product: HD Web Camera
[ 1575.323380] usb 4-1: Manufacturer: HD Web Camera
[ 1575.323398] usb 4-1: SerialNumber: Ucamera001
[ 1575.339413] usb 4-1: Found UVC 1.00 device HD Web Camera (05a3:9331)
[ 1575.385548] usb 4-1: Failed to query (GET_INFO) UVC control 12 on unit 2: -32 (exp. 1).
[ 1575.411675] usb 4-1: Failed to query (GET_INFO) UVC control 11 on unit 2: -32 (exp. 1).
[ 1575.439723] input: HD Web Camera: HD Web Camera as /devices/platform/soc/1c1c000.usb/usb4/4-1/4-1:1.0/input/input3
[ 1575.445541] usb 4-1: Warning! Unlikely big volume range (=3072), cval->res is probably wrong.
[ 1575.445585] usb 4-1: [6] FU [Mic Capture Volume] ch = 1, val = -1536/1536/1
Version 1.8.2 running on an Orange PI.
mjpg does not appear to be installed, so no mjpg-streaming. Webcamd does appear to be installed but nothing I do seems to kick it off.
[Edit] I found a webcamd.conf and changed video0 to video1. No change except it now shows webcamd already running.
I have no installed any updates since the camera was later
I just tested the camera on my laptop and it works fine.
What additional information do I need to post to help with this?
EDIT: I was able to use ffmpeg to capture from the camera to an mkv file and play it on my PC. I had to remove the 640x480 resolution - I guess it was trying to force it and couldn't.
EDIT 2-4-03 - problem solved. I used "motion", works fine now.
Thanks very much in advance.
khobar
