Can not get the webcam stream to work on either the local page or through the octopi.local/webcam/?action=stream address.
First I tried editing the settings in the /boot/octopi.txt file according to guides found online (changing the camera default from auto to raspi, different raspi settings according to this: https://github.com/PrusaMK2Users/MK2_Tips_and_Tricks/wiki/Octoprint-Webcam-Setup). After that did not work I tried a different stream url in the local settings. After all that failed I wiped the pi sd card and started over fresh. Ran raspi-config and updated to make sure that was all up to date. After no changes I tried editing the settings same as above. Also, during this whole time the raspi cam led was on. Assuming that means it was getting power/is connected correctly. The whole time there was no change. It's probably something really simple to see once I post the logs. I appreciate your help.
Up to date version of both OctoPrint and OctoPi. Most up to date version of the Marlin firmware.
/boot/octopi.txt
## Windows users: To edit this file use Notepad++, VSCode, Atom or SublimeText.
### Do not use Notepad or WordPad.
### MacOSX users: If you use Textedit to edit this file make sure to use
### "plain text format" and "disable smart quotes" in "Textedit > Preferences"
### Configure which camera to use
# Available options are:
# - auto: tries first usb webcam, if that's not available tries raspi cam
# - usb: only tries usb webcam
# - raspi: only tries raspi cam
# Defaults to auto
camera="auto"
### Additional options to supply to MJPG Streamer for the USB camera
# See https://faq.octoprint.org/mjpg-streamer-config for available options
# Defaults to a resolution of 640x480 px and a framerate of 10 fps
#camera_usb_options="-r 640x480 -f 10"
### Additional webcam devices known to cause problems with -f
# Apparently there a some devices out there that with the current
# mjpg_streamer release do not support the -f parameter (for specifying
# the capturing framerate) and will just refuse to output an image if it
# is supplied.
# The webcam daemon will detect those devices by their USB Vendor and Product
# ID and remove the -f parameter from the options provided to mjpg_streamer.
# By default, this is done for the following devices:
# Logitech C170 (046d:082b)
# GEMBIRD (1908:2310)
# Genius F100 (0458:708c)
# Cubeternet GL-UPC822 UVC WebCam (1e4e:0102)
# Using the following option it is possible to add additional devices. If
# your webcam happens to show above symptoms, try determining your cam's
# vendor and product id via lsusb, activating the line below by removing # and
# adding it, e.g. for two broken cameras "aabb:ccdd" and "aabb:eeff"
# additional_brokenfps_usb_devices=("aabb:ccdd" "aabb:eeff")
# If this fixes your problem, please report it back so we can include the device
# out of the box: https://github.com/guysoft/OctoPi/issues
#additional_brokenfps_usb_devices=()
### Additional options to supply to MJPG Streamer for the RasPi Cam
# Defaults to 10fps
camera_raspi_options="-x 1920 -y 1080 -fps 30 -quality 95 "
### Configuration of camera HTTP output
# Usually you should NOT need to change this at all! Only touch if you
# know what you are doing and what the parameters mean.
# Below settings are used in the mjpg-streamer call like this:
# -o "output_http.so -w $camera_http_webroot $camera_http_options"
# Current working directory is the mjpg-streamer base directory.
#camera_http_webroot="./www-octopi"
#camera_http_options="-n"
pi@octopi:~ $ systemctl status webcamd
β webcamd.service - LSB: webcam daemon
Loaded: loaded (/etc/init.d/webcamd; generated; vendor preset: enabled)
Active: active (running) since Tue 2019-03-12 07:10:59 GMT; 2min 2s ago
Docs: man:systemd-sysv-generator(8)
Process: 408 ExecStart=/etc/init.d/webcamd start (code=exited, status=0/SUCCESS)
ββ429 /bin/bash /root/bin/webcamd
ββ467 ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_raspicam.so -x 1920 -y 1080 -fps 30 -quality 95
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: resolution........: 1920 x 1080
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: camera parameters..............:
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: www-folder-path......: ./www-octopi/
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: HTTP TCP port........: 8080
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: HTTP Listen Address..: (null)
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: username:password....: disabled
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: commands.............: disabled
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: starting input plugin input_raspicam.so
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: starting output plugin: output_http.so (ID: 00)
Mar 12 07:11:00 octopi mjpg_streamer[467]: MJPG-streamer [467]: Starting Camer
Starting up webcamDaemon...
camera: auto
usb options: -r 640x480 -f 10
raspi options: -x 1920 -y 1080 -fps 30 -quality 95
http options: -w ./www-octopi -n
<13>Mar 12 07:11:00 pi: Starting Raspberry Pi camera
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_raspicam.so -x 1920 -y 1080 -fps 30 -quality 95
MJPG Streamer Version: git rev: ddb69b7b4f114f3c2ca01adf55712792ca8aed43
i: fps.............: 30
i: resolution........: 1920 x 1080
i: camera parameters..............:
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
o: HTTP Listen Address..: (null)
i: Starting Camera
Encoder Buffer Size 81920
Gonna be out of pocket for 6-7 hours. I'll reply if you need more info asap. Thanks ahead of time.
Tyler
