Webcam won’t display. Help!
I have an Ender 3 pro printer
I just got a raspberry pi 3 A+ and a raspberry pi camera
I’m powering the pi using the printer psu with a buck converter
However the camera is not displaying anything on the octoprint site.
I tried rebooting the pi multiple times. Checked the ribbon cables few times. The camera turns on the pi detects the camera when I check via ssh terminal. But it’s not displaying anything. It says
Blockquote
Webcam stream loading…
Blockquote
I tried a different raspberry with the default
Raspbian os with the same camera everything worked
I tried the same pi with Raspbian os it also worked.
It’s just when I use octopi that the camera doesn’t work
Yes. Still didn’t work
Nop
What happens when you open this url in your browser http://octopi.local/webcam/?action=stream
Nothing really
It sends me to a page that take a long time to load. And then nothing
I tried sudo vcgencmd get_camera
And got
Supported=1 detected=1
However when I try
I get this
I checked all the connections
The camera board lights up red
I tried everything here
Still nothing is displaying
I checked vcgencmd get_camera
I get an error message (no data received from sensor.)
Please keep this in one thread :slight_smile:
I moved your second post back to this thread
Did you update ? sudo apt-get … I had to do this on mine to get camera working. You can probably just raspi-config to do the update if you’re not familiar with commands in a terminal window
