Logitech C922
Webcam stream loading... Not loaded loop. No still frame or stream.
Webcamd not starting properly.
Check usb is recognized
pi@Enders:~ $ lsusb
Bus 001 Device 005: ID 046d:085c Logitech, Inc. C922 Pro Stream Webcam
Check service status
service webcamd status
β webcamd.service - the OctoPi webcam daemon with the user specified config
Active: failed (Result: start-limit-hit) since Wed 2021-05-12 05:31:49 BST; 2min 42s ago
Process: 621 ExecStart=/root/bin/webcamd (code=exited, status=0/SUCCESS)
May 12 05:31:49 Enders systemd[1]: webcamd.service: Service RestartSec=100ms expired, scheduling restart.
May 12 05:31:49 Enders systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 5.
May 12 05:31:49 Enders systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
May 12 05:31:49 Enders systemd[1]: webcamd.service: Start request repeated too quickly.
May 12 05:31:49 Enders systemd[1]: webcamd.service: Failed with result 'start-limit-hit'.
May 12 05:31:49 Enders systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
Check Log
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 1920x1080 -f 10 -y -d /dev/video0
MJPG Streamer Version: git rev: 85f89a8c321e799fabb1693c5d133f3fb48ee748
ERROR: could not find input plugin
Perhaps you want to adjust the search path with:
# export LD_LIBRARY_PATH=/path/to/plugin/folder
dlopen: libv4l2.so.0: cannot open shared object file: No such file or directory
Edit boot/octopi.txt
camera="usb"
camera_usb_options="-r 1920x1080 -f 10 -y"
webcamd.log (69.4 KB)
syslog.log (570.0 KB)
Octoprint: 1.6.1
OctoPi: Version 0.18.0, running on Raspberry Pi 3 Model B Rev 1.2
