Camera Model : Logitech C525
Whats is the problem?
Have installed mjpeg-streamer (a couple of of ways via various tutorials), and the camera works fine. Zero issues getting a stream.
I then put the Stream URL into the OctoPrint Settings Stream URL, and try to test the camera, and get nothing. But the SnapShot works fine, I get an image
Saving the settings, I then go to the control tab I get a black window with a "Stream not loaded message" This text contains a link to the currently configured stream, following that link takes me to a perfectly working stream.
Install mjpeg-streamer a couple of differnt ways
Read every post on this forum that even hinted like it might have the answer, tried a few things from various posts but no change.
I have looked at various logs, and nothing shows anything interesting that I can see. I would rate myself as intermediate experience using Linux. Can extract logs if someone is looking for sepcific detail
OctoPrint 1.3.12
I am not using the Octopi image, as I use my pi for other things as well (mostly MQTT / NodeRed), so I installed it manually using the install guide. OctoPrint seems to be working just fine, its a couple of hours into a print as I type this.
