I've recently setup an OpenVAS server on my network, just to occasionally scan and keep tabs on any necessary updates (I'm bored, it's Quarantine, it was a fun project). I've noticed that when it scans my 2 Raspberry Pi's running OctoPi, it kills the webserver. Any prints keep running, and I can still access the Webcam feed, however the webserver dies and I get the "Octoprint is currently not running" webpage. The server is still running, as plugins like PushOver, Spaghetti Detective, the Enclosure plugin, are still running and responding. I just have no way to get to the UI and do any controls.
In the logs there is a TON of output, as the scanner is trying all the different wordpress and such URL's.. Most of it is flagged as Warning, however there is this one section containing a handful of errors:
2020-10-30 13:09:25,210 - tornado.access - WARNING - 404 GET /SiteScope/htdocs/SiteScope.html (::ffff:192.168.4.86) 15.91ms
2020-10-30 13:09:25,372 - tornado.access - WARNING - 404 GET /NonExistent107688498/ (::ffff:192.168.4.86) 16.75ms
2020-10-30 13:09:25,399 - octoprint.server.views - WARNING - Client requested cache refresh via cache-control headers but we are printing. Not invalidating caches due to resource limitation. Append ?_refresh=true to the URL if you absolut
ely require a refresh now
2020-10-30 13:09:25,507 - tornado.access - WARNING - 404 GET /ControlManager/default.htm (::ffff:192.168.4.86) 8.69ms
2020-10-30 13:09:25,562 - tornado.application - ERROR - Uncaught exception GET /static/webassets/non-existent-446477620 (::ffff:192.168.4.86)
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/web.py", line 1590, in _execute
result = method(*self.path_args, **self.path_kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/tornado.py", line 1013, in get
if self.should_use_precompressed():
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/util/tornado.py", line 1002, in should_use_precompressed
and "gzip" in self.request.headers.get("Accept-Encoding"))
TypeError: argument of type 'NoneType' is not iterable
2020-10-30 13:09:25,565 - tornado.access - ERROR - 500 GET /static/webassets/non-existent-446477620 (::ffff:192.168.4.86) 3.48ms
2020-10-30 13:09:25,578 - tornado.access - WARNING - 404 GET /ControlManager/default.htm (::ffff:192.168.4.86) 9.28ms
2020-10-30 13:09:25,585 - tornado.application - ERROR - Uncaught exception GET /static/webassets/non-existent-1458004078 (::ffff:192.168.4.86)
2020-10-30 13:09:25,588 - tornado.access - ERROR - 500 GET /static/webassets/non-existent-1458004078 (::ffff:192.168.4.86) 3.78ms
2020-10-30 13:09:26,001 - tornado.access - WARNING - 404 GET /home/monitoring.cgi (::ffff:192.168.4.86) 9.53ms
2020-10-30 13:09:26,078 - tornado.access - WARNING - 404 GET /home/monitoring.cgi (::ffff:192.168.4.86) 10.37ms
2020-10-30 13:09:26,199 - tornado.access - WARNING - 404 GET /NonExistent446240993/ (::ffff:192.168.4.86) 12.72ms
2020-10-30 13:09:26,225 - octoprint.server.views - WARNING - Client requested cache refresh via cache-control headers but we are printing. Not invalidating caches due to resource limitation. Append ?_refresh=true to the URL if you absolutely require a refresh now
2020-10-30 13:09:26,387 - tornado.application - ERROR - Uncaught exception GET /static/webassets/non-existent-1522345911 (::ffff:192.168.4.86)
2020-10-30 13:09:26,391 - tornado.access - ERROR - 500 GET /static/webassets/non-existent-1522345911 (::ffff:192.168.4.86) 4.95ms
2020-10-30 13:09:26,407 - tornado.application - ERROR - Uncaught exception GET /static/webassets/non-existent-1985860661 (::ffff:192.168.4.86)
2020-10-30 13:09:26,411 - tornado.access - ERROR - 500 GET /static/webassets/non-existent-1985860661 (::ffff:192.168.4.86) 4.65ms
2020-10-30 13:09:26,589 - tornado.access - WARNING - 404 GET /cpqlogin.htm (::ffff:192.168.4.86) 10.74ms
2020-10-30 13:09:26,661 - tornado.access - WARNING - 404 GET /cpqlogin.htm (::ffff:192.168.4.86) 15.31ms
I'm running 2 instances of Octoprint, both on PI 3B+'s with the latest official release (One on Python3, one still on Python2). They're being scanned by another Raspberry Pi (4) running OpenVAS & Greenbone, scanner v5.1.3 (Yes, it's old).
Anyone know a good way to kick the webserver back into operation? Or recognize a bug that needs to be handled better?
