I recently installed OctoPi 32-bit on my Raspberry Pi 400 for my Prusa MK3S+ printer. However, the UI is very unresponsive and I was able to track it down to the web socket not connecting. Any ideas on how to fix this?
I uninstalled all my plugins and looked through the log files. I couldn't find any errors in the logs. I also tried enabling CORS in the API settings.
Yes
octoprint-systeminfo-20231026132612.zip (1.1 MB)
Raspberry Pi 400 with Prusa MK3S+ printer with Logitech 720p Webcam
