I am trying to configure a multi material printer to be controlled by Octoprint. The build plate is 200x200. If I take the lower left corner of that build plate as the origin, then when I home my X and Y axes, extruder_0 will be a (-55, -5) in "bed cordinates". Extruder_1 will be at (-13,-5) in "bed coordinates". So is my custom bounding box X=-55/200, Y=-5,200 ? And is extruder Xoffset = 43?
That did not seem to prevent me from moving the print head past the right hand edge of the build plate or is the movement controls not limited by the custom bounding box? Is it only used to warn you about out of bounds movement in gcode and actually does not stop moving outside that bounding box.
