I just upgraded to 1.5.0 and lost the control to "select tool". On the Control tab under Tool there used to be a "select tool" dropdown menu. It is necessary to select the tool before sending extrusion commands for priming the extruder either via the extrude buttons on the same tab or via a gcode command such as G1 E100 F5000. Attempting to prime the extruder without selecting the tool puts my machines into an error state which causes the board to reboot.
I have a work-around to accomplish this via the Duet mainboard but would like this functionality restored to Octoprint.
Complete Logs
From terminal:
Send: G1 E5 F300
Recv: ok
Recv: Error: Attempting to extrude with no tool selected.
Send: M82
Changing monitoring state from "Operational" to "Error: Attempting to extrude with no tool selected."
Send: M112
Send: N3 M11234
Send: N4 M104 T0 S037
Send: N5 M140 S0*96
Changing monitoring state from "Error: Attempting to extrude with no tool selected." to "Offline (Error: Attempting to extrude with no tool selected.)"
I think that is hidden when there is only one tool, is this the case for your printer? If not we may be able to get a custom control for you - or it is a bug.
It was not hidden prior to update. As most printers only have one tool and there are extrude and retract buttons that don't work without selection of a tool, it seems like a bug. The error may be a feature of the Duet board and its' firmware though and may not present with other firmware.
Sorry, that was not clear - it is a new thing, that the UI is improved now as select tool is redundant on single tool extruders.
What firmware are you using? Since (I don't think) this is not a problem on Marlin Firmware, at least for me. If you could enable serial log, reconnect to printer and then upload it that would be good.
@Ewald_Ikemann It is in the release notes, I was involved in the conversation about removing it... Think this might have been overlooked that some FW requires it even for single tool.
I'll look and see if (a) a single file plugin to fix this for you can be made, or something to put in the custom controls are.
Try going to the printer profile & increasing the number of extruders. I need to check what side effects it has, but it will re-show the button for you. If it breaks other things, then we will go down the single file plugin (temp fix) and get it fixed for the next release, with RRF.
I think I have a solution. I just added a "T0" under "Settings> Gcode Scripts> After connection to printer is established". Problem solved. Thanks again!
