I installed the bed visualizer plugin, and it works fine for the most part. It works with my CR touch and sends the results fine. Other than the actual visual output of the bed. I tried to find the reason on here but it seems like I am the only one who is having this issue. Any help is appreciated.
I tried to uninstall and reinstall the plug-in.
I tired running in safe mode.
The issue did not get solved.
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
 OctoPrint 1.8.0
              That kind of seems like it could be a rendering issue in the browser or something - what browser/OS versions is it?
              I think I have one more report from someone else running on a Mac with this same issue. I don't know what actually causes it and have attempted a couple of plotly library upgrades trying to fix it and nothing has worked so far. Definitely would like to know what browser.
        opened 03:21AM - 09 Jan 22 UTC
          bug
    **Describe the bug**
Mesh is not visualized, instead I see a cloud of dots.
β¦ **Expected behavior**
I expect to see a solid "sheet" that portrays the different bed heights captured.
**Debug Log**
[plugin_bedlevelvisualizer_debug.log](https://github.com/jneilliii/OctoPrint-BedLevelVisualizer/files/7834404/plugin_bedlevelvisualizer_debug.log)
**Screenshots**
**Firmware and Version**
Marlin 2.0.7.2
              I was using safari. I opened it up in chrome and it works. I guess I will just stick with chrome. Thank you!
                system
                    August 20, 2022, 11:23pm
                  5
