What is with all the "Recv: busy:processing" messages?
With OctoPrint 1.3.10 I'm getting
Printer seems to support the busy protocol, adjusting timeouts and setting busy interval accordingly
and then a lot of
Nothing yet, printer is still printing
OctoPi 0.14, OctoPrint 1.3.10, LulzBot TAZ 6, Marlin 1.1.9.28
Those messages come from your firmware. It's the firmware telling any connected host that it's currently really busy with something (e.g. a blocking heatup, homing or other long running command) and therefore cannot receive and process any new commands for the time being.
Any chance of getting OctoPrint to suppress those messages? A check box like "Suppress temperature"?
Terminal filters are configurable via Settings > Terminal filters, so just add a filter there and it will pop up as a new checkbox.
Recv: busy:processing should work as RegExp.
This is old topic and in version 1.3.11 we already have 'Suppress temperature messages' checkbox associated with the filter
(Send: (N\d+\s+)?M105)|(Recv:\s+(ok\s+((P|B|N)\d+\s+)*)?(B|T\d*):\d+)
However, if you are in the process of troubleshooting or building new printer and temporarily disconnect thermal sensor of tool 0, the temperature value may turn negative and above filter won't apply. The fix is easy - just add '-?' in front of the last \d.
(Send: (N\d+\s+)?M105)|(Recv:\s+(ok\s+((P|B|N)\d+\s+)*)?(B|T\d*):-?\d+)
This was tested and worked with Repetier firmware.
