I don't really need help since it all works, this is more about understanding what happens.
I configured Marlin (2.0.9.1) for 250000 baud instead of the prior 115200 baud.
Then set the connection settings top-left to AUTO on port and AUTO on baud rate and turned the printer's power on. the log goes like:
2021-11-24 18:17:01,423 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2021-11-24 18:17:01,479 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
2021-11-24 18:17:01,480 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyACM0, baudrate 115200
2021-11-24 18:17:01,481 - octoprint.util.comm - INFO - Connecting to port /dev/ttyACM0, baudrate 115200
2021-11-24 18:17:01,495 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2021-11-24 18:17:01,502 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-11-24 18:17:03,505 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2021-11-24 18:17:03,515 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-11-24 18:17:05,472 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2021-11-24 18:17:05,510 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-11-24 18:17:05,626 - octoprint.plugins.stats - INFO - Printer Stats - on_event
2021-11-24 18:17:05,955 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 2.0.9.1 (Nov 24 2021 15:56:51)"
And this is, what the ui tells me: 115200.
Did a test print, no problem whatsoever.
Disconnected, set baudrate to 250000, connect.
OctoPrint is fine with it:
2021-11-24 18:22:26,704 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2021-11-24 18:22:26,713 - octoprint.util.comm - INFO - Connecting to port /dev/ttyACM0, baudrate 250000
2021-11-24 18:22:26,759 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2021-11-24 18:22:26,775 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-11-24 18:22:26,794 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-11-24 18:22:26,805 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2021-11-24 18:22:26,931 - octoprint.plugins.stats - INFO - Printer Stats - on_event
2021-11-24 18:22:26,953 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-11-24 18:22:27,304 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 2.0.9.1 (Nov 24 2021 15:56:51)"
2021-11-24 18:22:27,372 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2021-11-24 18:22:27,452 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting for an acknowledgement first
Another test print, all is smooth.
Still, I'm confused.
Does the baud rate not matter? I'd have expected an error.
Auto-detection did not detect Marlin's configured baud rate even though 250000 is one of the values it states to check. Apparently it received a handshake on the first attempt and settled for that.
octoprint-systeminfo-20211124183221.zip (676.7 KB)
This is 1.7.2 on 0.18.0, raspi 3B+
