When I send a 200M gcode, an error will be prompted, what is the reason, please solve it. . and I am using octoprint
Hello @slayercjc !
More easy said as done.
There was a template that asked for some information.
Where is it gone?
It was there to help us to help you.
Aaand: 200M, does that mean a 200 MByte file?
Also, have you checked for a proper connection from PrusaSlicer to Octoprint from within the PrusaSlicer settings?
I just tested it, and an error will be reported if the file is larger than 30M. There is no problem with small files. I tested that prusaslicer can be linked with otcoprint normally.
you still need to supply all the requested information of the original form.
