When printing to OctoPrint from Cura, OctoPrint will frequently act as though the print has finished already
After I slice a model in Cura (5.5.0) and click "Print With OctoPrint", Octoprint will frequently load the model, take it to 100% right away, and do nothing else. The code displayed on the terminal is:
Changing monitoring state from "Operational" to "Starting"
Send: N0 M110 N0125
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Changing monitoring state from "Printing" to "Finishing"
Send: N1 M400
38
Recv: ok
Changing monitoring state from "Finishing" to "Operational"
Restarting my PC, the printer, and the RaspberryPi
Yes
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/134.0.0.0 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1000.0
env.hardware.ram: 380948480
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi Zero 2 W Rev 1.0
env.plugins.pi_support.octopi_camera_stack: webcamd
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.octopiuptodate_build: 1.0.0-1.10.3-20241105092907
env.plugins.pi_support.octopiuptodate_build_short: 2024.11.05.092907
env.python.pip: 22.3
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2025-04-01T21:59:58Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: False
octoprint.version: 1.10.3
printer.firmware: Marlin 2.1.1 (May 20 2023 00:19:16)
systeminfo.generated: 2025-04-02T23:14:54Z
systeminfo.generator: zipapi
OctoPrint Version 1.10.3
Build 2024.11.05.092907 with "webcamd", based on OctoPi 1.0.0, running on Raspberry Pi Zero 2 W Rev 1.0
Elegoo Neptune 3 Pro
Hello @Crunchy409 !
  1. Check, if there is a non command line at the end of the gcode-file.
  2. Attach the systeminfo bundle to your next post.
Thanks for the response!!
I have attached the bundle.
I never thought to look at the straight gcode- thanks for that incredibly simple solution! I noticed immediately that the gcode output from Cura lacked.... gcode! It was almost purely a huge long string representing the thumbnail produced by a thumbnail plugin for Cura. I uninstalled this plugin and haven't had any trouble since. I appreciate your time!
octoprint-systeminfo-20250403001454.zip (461.3 KB)
