Where can you copy a cura profile to an SD card image? I don't mean import it I mean if creating an image in advance for a few installs but need to add the profiles before hand.
Some are for higher% infills or different settings and others for widely different materials and printers etc.
I mean the files that contain these that would get from a cura export.
e.g.
[general]
version = 4
name = M1KTA Own Settings
definition = workshop1
[metadata]
type = quality_changes
position = 0
quality_type = draft
setting_version = 4
[values]
infill_pattern = grid
ironing_enabled = True
retraction_amount = 7
retraction_speed = 70
skin_line_width = 0.35
skirt_line_count = 1
speed_infill = 80
speed_layer_0 = 20.0
speed_print = 50
speed_print_layer_0 = 15.0
speed_travel_layer_0 = 30
speed_wall = 40.0
speed_wall_x = 60.0
top_bottom_pattern = lines
top_bottom_thickness = 0.8
wall_line_width_0 = 0.35
wall_line_width_x = 0.35
wall_thickness = 1.2
