Cannot find the Haproxy config to edit settings.
Looked on the SD card, did not see anythign related to Hapoxy. Meant to be preinstalled here /etc/haproxy/haproxy.cfg ??
Octopi 0.15 with Raspberry Pi 3
OctoPrint version : 1.3.8
OctoPi version : 0.15.0
pi@octopi3p:~ $ ls -la /etc/haproxy/haproxy.cfg
-rw-r--r-- 1 root root 1179 Jul 17 2017 /etc/haproxy/haproxy.cfg
All there.
Is the etc folder meant to show on the SD card when plugged into windows?
No. You need to SSH into it for that. What shows under Windows is only a fraction of the whole file system, a special partition for some very basic/hen-egg style of configuration. For anything else you need SSH.
Oh right, so once I log into my Pi I should type in sudo nano /etc/haproxy/haproxy.cfg and this will bring me to the config file?
Yes. But best make a copy before so in case you make a mistake when you change things, you can easily roll back to a working state:
cp /etc/haproxy/haproxy.cfg ~/haproxy.cfg.bck
You will be able to restore this then with
sudo cp ~pi/haproxy.cfg.bck /etc/haproxy/haproxy.cfg
Great thanks for the help
