Where do I place @xinput set-prop TSTP MTouch Coordinate Transformation Matrix -1 0 1 0 -1 1 0 0 1
for startup? I'm using TouchUI - Interface, and the 3 usual autostarts only works with booting to the X-Windows (wich the TouchUI-Interface does not seem to start.
/etc/xdg/lxsession/LXDE-pi/autostart
/home/user/.config/lxsession/LXDE-pi/autostart
/home/user/.config/autostart/
--working fine when I boot to X, but not to touchUI
If your /boot/config.txt has an entry near the bottom which begins with dtoverlay then look into configuring your TFT screen there. The arguments should support rotating either/both the display itself and the touchscreen portion.
Refer to the conversation I had with Ada (of Adafruit) regarding this same topic. Most vendors assume you'll be in the x windows system and never even imagine that you might need this to work at the terminal level.
Well the above xiput-line is just an example. It's not about only rotating (seems to be richt already) but calibrating the whole geekcreit TFT35 via the matrix I have still to calculate. Where and how to calibrate this?
Right now I can move the cursor to the corners I tap on, but no chance with someting in die middle...
Ok, the dtoverlay can change the orientation and I can use the waveshare drivers.
On the Adafruit Tutorial I gut stuck on
`sudo apt-get install evtest tslib libts-bin resulting in "tslib not found".
evtest command not found
after gitting & compiling tslib I get "shared object libts.so.0 not found".
tslib is the crucial part for calibration without x, right? Or is there a different approach?
solved.
In a strange way.
-First I switched back to X via LCD35-show (Provided with the Touchscreen drivers).
-then I tried xinput set of the transformation matrix. Sort of worked, but still cursor was jumping big steps (but at least to almost the right places).
-Resetted the matrix to standard.
-found out via xinput list-props that there where malformed evdev settings. Set them to something more convinient. Than it sort of worked. used xinput-calibration the get better values, wrote them to
/etc/X11/xorg.conf.d/99-calibration.conf. (+ an axis inversion for x).
After the next reboot, it took me to the TouchUI Interface (don't know why). And there it also worked.
