I'm running Octoprint 1.4.0 on an RPi 3B+ (octopi version 0.15.1). My uptime is 62 days. I just logged into my Pi and noticed that there are over 2,800 "Snapshot" PNG files in my /tmp directory:
-rw------- 1 pi pi 29711 Jul 26 21:22 Snapshot_05556506cfb011ea9309b827eb454a43.png
-rw------- 1 pi pi 25812 Jul 26 21:24 Snapshot_3d6b2f48cfb011eabad6b827eb454a43.png
-rw------- 1 pi pi 24978 Jul 26 21:27 Snapshot_b1986962cfb011eabb0db827eb454a43.png
-rw------- 1 pi pi 24277 Jul 26 21:28 Snapshot_e923dc68cfb011ea9b8ab827eb454a43.png
-rw------- 1 pi pi 25117 Jul 26 21:30 Snapshot_209bbc24cfb111ea93ebb827eb454a43.png
-rw------- 1 pi pi 26916 Jul 26 21:33 Snapshot_93cb17eecfb111ea84c8b827eb454a43.png
-rw------- 1 pi pi 28572 Jul 26 21:35 Snapshot_cc4cb816cfb111eaab7eb827eb454a43.png
-rw------- 1 pi pi 26582 Jul 26 21:36 Snapshot_046d6f9ccfb211ea888cb827eb454a43.png
-rw------- 1 pi pi 27335 Jul 26 21:40 Snapshot_775c8524cfb211eab4c9b827eb454a43.png
-rw------- 1 pi pi 25743 Jul 26 21:41 Snapshot_b077ae4ccfb211eaa27bb827eb454a43.png
-rw------- 1 pi pi 27105 Jul 26 21:43 Snapshot_e8412934cfb211ea8ea3b827eb454a43.png
Does anyone know where these are coming from, and how I can stop them from being created?
2020-07-27 16:32:07,722 - octoprint.startup - INFO - ******************************************************************************
2020-07-27 16:32:07,724 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-07-27 16:32:07,725 - octoprint.startup - INFO - ******************************************************************************
2020-07-27 16:32:07,793 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-07-27 16:32:07,798 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2020-07-27 16:32:07,848 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-07-27 16:32:10,258 - octoprint.plugin.core - INFO - Plugin Octoslack (2.0.0) is disabled.
2020-07-27 16:32:11,633 - octoprint.plugin.core - INFO - Found 32 plugin(s) providing 31 mixin implementations, 63 hook handlers
2020-07-27 16:32:12,470 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-07-27 16:32:12,500 - octoprint.server - INFO - Intermediary server started
2020-07-27 16:32:12,501 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-07-27 16:32:13,371 - octoprint.plugin.core - INFO - Found 32 plugin(s) providing 31 mixin implementations, 63 hook handlers
2020-07-27 16:32:13,421 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-07-27 16:32:14,220 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-07-27 16:32:14,226 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-07-27 16:32:14,227 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-07-27 16:32:14,228 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-07-27 16:32:14,229 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-07-27 16:32:14,231 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-07-27 16:32:14,233 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-07-27 16:32:14,236 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-07-27 16:32:14,236 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-07-27 16:32:14,238 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-07-27 16:32:14,240 - octoprint.server - INFO - Added new permission from plugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_printer_safety_check_display')")
2020-07-27 16:32:14,242 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-07-27 16:32:14,244 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-07-27 16:32:14,260 - octoprint.printer.standard - INFO - Using print time estimator provided by PrintTimeGenius
2020-07-27 16:32:14,659 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-07-27 16:32:16,973 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-27 16:32:19,173 - octoprint.util.pip - INFO - Version of pip is 9.0.3
2020-07-27 16:32:19,174 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-07-27 16:32:19,176 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-07-27 16:32:19,181 - octoprint.plugin.core - INFO - Initialized 31 plugin implementation(s)
2020-07-27 16:32:19,232 - octoprint.plugin.core - INFO - 32 plugin(s) registered with the system:
| Access Anywhere - The Spaghetti Detective (1.3.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_thespaghettidetective
| Bed Visualizer (0.1.14) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| Enclosure Plugin (4.12) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_enclosure
| Filament Manager (0.5.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentmanager
| FileManager (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager
| Firmware Updater (1.7.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| Fullscreen Plugin (0.0.5) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fullscreen
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
| MultiCam (0.2.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_multicam
| Navbar Temperature Plugin (0.14) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_navbartemp
| !Octoslack (2.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_Octoslack
| Printoid Plugin (1.0.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_printoid
| PrintTimeGenius Plugin (2.2.5) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| Prusa Leveling Guide (1.0.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrusaLevelingGuide
| PrusaSlicer Thumbnails (0.1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_prusaslicerthumbnails
| Python 3 Check (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_python3plugincompatibilitycheck
| TouchUI (0.3.14) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_touchui
| TP-Link Smartplug (0.9.23) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_tplinksmartplug
2020-07-27 16:32:19,254 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 918192128
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.15.1
| python:
| pip: 9.0.3
| version: 2.7.13
| virtualenv: /home/pi/oprint
2020-07-27 16:32:19,274 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-07-27 16:32:19,306 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-07-27 16:32:21,053 - octoprint.server - INFO - Shutting down intermediary server...
2020-07-27 16:32:21,056 - octoprint.server - INFO - Intermediary server shut down
2020-07-27 16:32:21,060 - octoprint.events - INFO - Processing startup event, this is our first event
2020-07-27 16:32:21,064 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2020-07-27 16:32:21,071 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-07-27 16:32:21,128 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-07-27 16:32:21,126 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-07-27 16:32:21,129 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-07-27 16:32:21,236 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-07-27 16:32:21,269 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "MK3s"' for _http._tcp
2020-07-27 16:32:21,363 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "MK3s"' for _octoprint._tcp
2020-07-27 16:32:21,673 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "MK3s" for SSDP
2020-07-27 16:32:23,180 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-07-27 16:32:23,236 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-07-27 16:32:23,403 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-07-27 16:32:25,503 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-07-27 16:32:25,865 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-07-27 16:32:25,867 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-07-27 16:32:25,868 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-07-27 16:32:25,935 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2020-07-27 16:32:25,973 - octoprint.plugins.multicam - INFO - MultiCam Loaded! (more: [{'isButtonEnabled': False, 'name': 'Nozzle', 'URL': '/webcam/?action=stream', 'streamRatio': '16:9', 'flipV': False, 'snapshot': 'http://127.0.0.1/webcam/?action=snapshot', 'flipH': False, 'rotate90': False}, {'isButtonEnabled': True, 'name': 'Overhead', 'URL': 'http://192.168.1.5:8081/?action=stream', 'streamRatio': '16:9', 'flipV': False, 'snapshot': 'http://127.0.0.1:8081/?action=snapshot', 'flipH': False, 'rotate90': False}, {'isButtonEnabled': True, 'name': 'Filament', 'URL': 'http://192.168.1.38:8080/video', 'streamRatio': '16:9', 'flipV': False, 'snapshot': 'http://127.0.0.1:8081/?action=snapshot', 'flipH': False, 'rotate90': False}])
2020-07-27 16:32:25,985 - octoprint.plugins.printoid - INFO - Printoid loaded!
2020-07-27 16:32:26,010 - octoprint.plugins.tplinksmartplug - INFO - TPLinkSmartplug loaded!
2020-07-27 16:32:27,054 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.4
2020-07-27 16:32:27,374 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.local/'}
2020-07-27 16:32:27,448 - octoprint.server.util.flask - INFO - Passively logging in user _admin from ::ffff:192.168.1.4
2020-07-27 16:32:27,452 - octoprint.access.users - INFO - Logged in user: _admin
2020-07-27 16:32:27,505 - octoprint.server.util.sockjs - INFO - User _admin logged in on the socket from client ::ffff:192.168.1.4
2020-07-27 16:32:27,549 - octoprint.plugins.thespaghettidetective - INFO - User account: {u'is_pro': False}
2020-07-27 16:32:34,067 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.4
2020-07-27 16:32:34,196 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.4
2020-07-27 16:32:34,544 - octoprint.server.util.flask - INFO - Passively logging in user _admin from ::ffff:192.168.1.4
2020-07-27 16:32:34,547 - octoprint.access.users - INFO - Logged in user: _admin
2020-07-27 16:32:34,587 - octoprint.server.util.sockjs - INFO - User _admin logged in on the socket from client ::ffff:192.168.1.4
2020-07-27 16:32:46,372 - octoprint.server.preemptive_cache - INFO - ... done in 19.00s
2020-07-27 16:32:46,374 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.5/'}
2020-07-27 16:32:52,898 - octoprint.server.preemptive_cache - INFO - ... done in 6.52s
2020-07-27 16:36:55,641 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.4
