I have a CR10 Mini using an MKS Gen L board. It prints really well off the SD card but I get stutters when printing with OctoPrint.
Looking at the terminal out put I can see that there's a communication timeout followed by a checksum error and a resend request. These only happen when an M105 is sent to the printer. I don't see why Octoprint is polling for temperature when M155 Autoreport is active and working. Here's a snippet of the terminal output.
Send: N510 G1 X110.220 Y123.404 E19.4474109
Recv: T:215.47 /216.00 B:60.00 /60.00 @:77 B@:38
Recv: T:216.15 /216.00 B:60.00 /60.00 @:66 B@:37
Recv: T:216.25 /216.00 B:60.02 /60.00 @:64 B@:30
Recv: T:215.78 /216.00 B:59.95 /60.00 @:72 B@:51
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Send: N511 M10534
Recv: Error:checksum mismatch, Last Line: 509
Recv: Resend: 510
Recv: ok
Recv: ok
Send: N511 M10534
Recv: ok T:215.78 /216.00 B:59.95 /60.00 @:72 B@:51
Send: N512 G1 X132.185 Y101.440 E20.4392*102
I have adjust the polling and autoreport intervals and can see that changing these can reduce the number of communications errors if the polling period is lengthened.
It seems that the printer is struggling to service the G1 command when it gets the M105, causing the timeout. The 'problem' would go away if the M105 wasn't sent when the M155 reports are active. I don't understand why this doesn't happen. Is there a way to turn off M105 requests?
Octoprint 1.3.10
Marlin 2.0 bugfix with BLtouch and Linear Advance
