ich mochte gerne den led streifen einbschalten wen ich printe und ausschalten wen der print fertig ist
Hallo.
Wie genau steuerst du den LED Streifen denn an?
Über einen Transistor und über den pi
Hi @Matthias_Oten,
need more details, because just switching LEDs is done (with python) like this:
(see https://tutorials-raspberrypi.de/raspberry-pi-gpio-erklaerung-beginner-programmierung-lernen/)
GPIO.setup(23, GPIO.OUT)
GPIO.output(23, GPIO.HIGH)
If you want to react on OctoPrint-Events you need to create a plugin and listen for an event.
class YourPlugin(
octoprint.plugin.EventHandlerPlugin
def on_event(self, event, payload):
if event == Events.FILE_SELECTED:
# change color of led-stuff
Nur so nebenbei: Die solltest deine Frage in englisch stellen, dann erreichst du mehr Antworten
Hi OllisGit
I have a similar problem and maybe you can help.
I want to control the fanspeed for the raspberry by by CPUtemperature.
For this I fojnd instruction to tell the pi to do so with a Phyton Script.
My question is: Where to put this script in an OctoPi environment, so I will alleays autostart and run in background.
Thanks for any suggestions.
