I have edited the file to configure the wifi and it will not conect. I have tried 4 different wifi networks and none of them work. It will work over ethernet though. I do not want to have to use my ethernet connection all the time for this so I want to use wifi.
I have tried solving it by trying different networks and connecting manually using the raspi config.
Im using a raspi model B+ with the intergrated wifi card.
Is your SSID hidden on your router configuration (commonly done for improved security)?
If so, you must add scan_ssid=1 to the config in /boot/wpa-supplicant.txt
