Looking for the Wiki for Octoprint and Smoothie. Want to review as I'm having serial issues with Smoothie pausing and killing print. Previously worked ok with Pi 2 but have updated to new raspberry pi 4 and now is having issues. Lost backup that worked.
Ignoring failure messages. Searches online for working settings.
Didn't try
Complete Logs
Nope, when I get back home. I can add
Latest builds, DIY Delta, Smoothieboard, Latest for Azteeg V2 mini board, Chrome, Windows 10, Simplify 3d for slicing.
I'm using Smoothie w/ OctoPrint w/o any serial comm issues on a Pi 4. Checked my setup and Smoothie is plugged into a USB 3.0 port.
Are you ignoring error handling messages?
Here's my terminal
WARNING! Received an error from the printer's firmware, ignoring that as configured but you might want to investigate what happened here! Error:
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Send: N15348 M10544
Recv: ok T:19.5 /0.0 @0 B:29.5 /0.0 @0
Send: N15349 M10545
Send: N15350 G1 X30.881 Y19.798 E2.721793
Recv: !!
Send: N15351 M10536
Recv: ok T:19.3 /0.0 @0 B:29.2 /0.0 @0
Send: N15352 M10539
Send: N15353 G1 X30.946 Y20.002 E2.729580
Recv: !!
Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3831
Please see https://faq.octoprint.org/serialerror for possible reasons of this.
Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3831)"
Nope. On a slightly older version though.
Build version: edge-bdb141f, Build date: Jan 12 2020 10:21:20, MCU: LPC1769, System Clock: 120MHz
