Will not connect on reboot, BUT
OctopPrint will not connect on reboot
BUT if I set to auto and let that error out then it goes ahead and connects to the default setting.Bundle
Rebooted everything several times
Yes, same
Build 2022.01.20.112925 with "webcamd", based on OctoPi 0.18.0, running on Raspberry Pi 4 Model B Rev 1.4
OctoPrint Version 1.9.3
Prusa MK3 s MMU2 3.13.1
Brave Version 1.59.124 Chromium: 118.0.5993.117 (Official Build) (64-bit)
Windows 10 home 22H2
Performing autodetection with 7 port/baudrate candidates: /dev/ttyS0@115200, /dev/ttyS0@250000, /dev/ttyS0@230400, /dev/ttyS0@57600, /dev/ttyS0@38400, /dev/ttyS0@19200, /dev/ttyS0@9600
Trying port /dev/ttyS0, baudrate 115200
Connecting to port /dev/ttyS0, baudrate 115200
Unexpected error while connecting to serial port /dev/ttyS0, baudrate 115200 from hook default: error: '(22, 'Invalid argument')' @ comm.py:_open_serial:3920
Could not open port /dev/ttyS0, baudrate 115200, skipping
Trying port /dev/ttyS0, baudrate 250000
Connecting to port /dev/ttyS0, baudrate 250000
Unexpected error while connecting to serial port /dev/ttyS0, baudrate 250000 from hook default: error: '(22, 'Invalid argument')' @ comm.py:_open_serial:3920
Could not open port /dev/ttyS0, baudrate 250000, skipping
Trying port /dev/ttyS0, baudrate 230400
Connecting to port /dev/ttyS0, baudrate 230400
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0xacbc9b90, open=True>(port='/dev/ttyS0', baudrate=230400, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Handshake attempt #2 with timeout 2.0s
Send: N0 M110 N0
125
Handshake attempt #3 with timeout 2.0s
Send: N0 M110 N0125
Trying port /dev/ttyS0, baudrate 57600
Send: N0 M110 N0
125
Send: N0 M110 N0125
Send: N0 M110 N0
125
Trying port /dev/ttyS0, baudrate 38400
Send: N0 M110 N0125
Send: N0 M110 N0
125
Send: N0 M110 N0125
Trying port /dev/ttyS0, baudrate 19200
Send: N0 M110 N0
125
Send: N0 M110 N0125
Send: N0 M110 N0
125
Trying port /dev/ttyS0, baudrate 9600
Send: N0 M110 N0125
Send: N0 M110 N0
125
Send: N0 M110 N0125
Changing monitoring state from "Detecting serial connection" to "Error"
Changing monitoring state from "Offline" to "Opening serial connection"
Changing monitoring state from "Opening serial connection" to "Connecting"
Connected to: Serial<id=0xacbc9eb0, open=True>(port='/dev/ttyS0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0
125
Recv: ok
Send: N0 M110 N0125
Changing monitoring state from "Connecting" to "Operational"
Recv: ok
Send: N0 M110 N0
125
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Prusa-Firmware 3.13.1 based on Marlin FIRMWARE_URL:GitHub - prusa3d/Prusa-Firmware: Firmware for Original Prusa i3 3D printer by PrusaResearch PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:AUTOREPORT_FANS:1
Recv: Cap:AUTOREPORT_POSITION:1
Recv: Cap:EXTENDED_M20:1
Recv: Cap:PRUSA_MMU2:1
Recv: ok
Send: M155 S2
Recv: ok
Recv: T:21.3 /0.0 B:21.1 /0.0 T0:21.3 /0.0 @:0 B@:0 P:0.0 A:29.7
You need to attach the system info bundle.
I am sorry, I thought I had done that...
Will check and find out what I did wrong...
octoprint-systeminfo-20231029190704.zip (116.9 KB)
