500 internal server error
Did reboot, reinstall
Yes
I'm using Windows 11
Try to using Anaconda and make virtual ( sorry I have no Idea, my first coding )
conda 23.7.4
python 3.11.5
OctoPrint 1.9.3
conda create -n [Octo] python=3.11.5
conda activate [Octo]
pip install octoprint
but I can't access web, http://localhost:5000 and hostIP:5000 (I don't know what is the host ip, I just found cmd - ipconfig)
- octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
- octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
- octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
- octoprint.plugin.core - INFO - Loading plugins from C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins, C:\Users\wogh4\AppData\Roaming\OctoPrint\plugins and installed plugin packages...
- octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2023.10.10) did not pass check, not loading.
- octoprint.plugin.core - INFO - Found 18 plugin(s) providing 18 mixin implementations, 34 hook handlers
- octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
- octoprint.server - INFO - Intermediary server started
- octoprint.filemanager.storage - INFO - Initializing the file metadata for C:\Users\wogh4\AppData\Roaming\OctoPrint\uploads...
- octoprint.filemanager.storage - INFO - ... file metadata for C:\Users\wogh4\AppData\Roaming\OctoPrint\uploads initialized successfully.
- octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
- octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
- octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
- octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
- octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_read'), Need(method='role', value='plugin_announcements_manage')")
- octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
- octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_GRANT (needs: "Need(method='role', value='plugin_appkeys_user')")
- octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
- octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")
- octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
- octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_LIST (needs: "Need(method='role', value='plugin_pluginmanager_list')")
- octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
- octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_manage'), Need(method='role', value='plugin_pluginmanager_install')")
- octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
- octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
- octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")
- octoprint.util.pip - INFO - Using "C:\Users\wogh4\anaconda3\envs\[Octo]\python.exe -m pip" as command to invoke pip
- octoprint.util.pip - INFO - Version of pip is 23.3
- octoprint.util.pip - INFO - pip installs to C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages (writable -> yes), --user flag needed -> no, virtual env -> no
- octoprint.util.pip - INFO - ==> pip ok -> yes
- octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
- octoprint.plugin.core - INFO - Initialized 18 plugin implementation(s)
- octoprint - INFO - Installing webcam compat overlay for configured default webcam <octoprint.webcams.ProvidedWebcam object at 0x0000026C8E574CD0>
- octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\action_command_notification
| Action Command Prompt Support (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\action_command_prompt
| Announcement Plugin (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\announcements
| Anonymous Usage Tracking (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\tracking
| Application Keys Plugin (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\appkeys
| Backup & Restore (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\backup
| Classic Webcam (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\classicwebcam
| Core Wizard (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\corewizard
| Discovery (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\discovery
| Error Tracking (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\errortracking
| Event Manager (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\eventmanager
| File Check (2021.2.23) (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint_file_check
| Firmware Check (2021.10.11) (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint_firmware_check
| GCode Viewer (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\gcodeviewer
| Logging (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\logging
| Plugin Manager (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\pluginmanager
| Software Update (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\softwareupdate
| Virtual Printer (bundled) = C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\plugins\virtual_printer
2023-11-01 16:03:43,222 - octoprint.environment - INFO - Detected environment is Python 3.11.5 under Windows (win32). Details:
| hardware:
| cores: 12
| freq: 2688.0
| ram: 16948453376
| os:
| bits: 64
| platform: win32
| python:
| pip: '23.3'
| version: 3.11.5
- octoprint.server - INFO - Reset webasset folder C:\Users\wogh4\AppData\Roaming\OctoPrint\generated\webassets...
- octoprint.server - INFO - Reset webasset folder C:\Users\wogh4\AppData\Roaming\OctoPrint\generated\.webassets-cache...
- octoprint.server - INFO - Reset webasset folder C:\Users\wogh4\AppData\Roaming\OctoPrint\generated\.webassets-manifest.json...
- octoprint.settings - WARNING - DeprecationWarning: Detected access to deprecated settings path ['webcam', 'snapshot'], returned value is derived from compatibility overlay. Please use the webcam system introduced with 1.9.0, this compatibility layer will be removed in a future release.
- octoprint.server - INFO - Shutting down intermediary server...
- octoprint.server - INFO - Intermediary server shut down
- octoprint.events - INFO - Processing startup event, this is our first event
- octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2023-11-01 16:03:43,569 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
- octoprint.server - INFO - Starting autorefresh of serial port list
- octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
- octoprint.server - INFO - Serial port list was updated, refreshing the port list in the frontend
- octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
- octoprint.server.util.watchdog - INFO - ... initial scan done.
- octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on JAEHO._http._tcp.local.' for _http._tcp.local.
- octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on JAEHO._octoprint._tcp.local.' for _octoprint._tcp.local.
- octoprint.plugins.discovery - INFO - Registered OctoPrint instance on JAEHO for SSDP
- octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000
- octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
- octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
- octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 275.0GB. That is considered sufficient for updating.
- octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
- octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://localhost:5000/', 'path': '/', 'query_string': 'l10n=en'}
- octoprint - ERROR - Exception on / [GET]
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\flask\app.py", line 2529, in wsgi_app
response = self.full_dispatch_request()
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\flask\app.py", line 1825, in full_dispatch_request
rv = self.handle_user_exception(e)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\flask\app.py", line 1823, in full_dispatch_request
rv = self.dispatch_request()
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\flask\app.py", line 1799, in dispatch_request
return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\views.py", line 697, in index
response = default_view()
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\views.py", line 668, in default_view
return preemptively_cached()
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\util\flask.py", line 1198, in decorated_function
return f(*args, **kwargs)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\util\flask.py", line 1280, in decorated_function
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\util\flask.py", line 1290, in decorated_function
r = f(*args, **kwargs)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\util\flask.py", line 936, in decorated_function
rv = f_with_duration(*args, **kwargs)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\util\flask.py", line 888, in f_with_duration
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\util\flask.py", line 1209, in decorated_function
rv = f(*args, **kwargs)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\util\flask.py", line 1234, in decorated_function
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\server\views.py", line 658, in make_default_ui
r = make_response(render_template("index.jinja2", **render_kwargs))
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\flask\templating.py", line 147, in render_template
return _render(app, template, context)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\flask\templating.py", line 130, in _render
rv = template.render(context)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\jinja2\environment.py", line 1301, in render
self.environment.handle_exception()
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\jinja2\environment.py", line 936, in handle_exception
raise rewrite_traceback_stack(source=source)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\templates\index.jinja2", line 17, in top-level template code
{% include 'javascripts-preload.jinja2' %}
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\octoprint\templates\javascripts-preload.jinja2", line 2, in top-level template code
{% assets "js_libs" %}<link rel="preload" as="script" href="{{ ASSET_URL }}">{% endassets %}
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\webassets\ext\jinja2.py", line 187, in _render_assets
urls = bundle.urls(calculate_sri=True)
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\webassets\bundle.py", line 833, in urls
urls.extend(bundle._urls(new_ctx, extra_filters, *args, **kwargs))
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\webassets\bundle.py", line 767, in _urls
self._build(ctx, extra_filters=extra_filters, force=False,
File "C:\Users\wogh4\anaconda3\envs\[Octo]\Lib\site-packages\webassets\bundle.py", line 622, in _build
raise BuildError('Nothing to build for %s, is empty' % self)
webassets.exceptions.BuildError: Nothing to build for <Bundle output=webassets/packed_libs.js, filters=[<octoprint.server.util.webassets.SourceMapRemove object at 0x0000026C91460290>, <octoprint.server.util.webassets.RJSMinExtended object at 0x0000026C914606D0>, <octoprint.server.util.webassets.JsDelimiterBundler object at 0x0000026C91460710>, <octoprint.server.util.webassets.GzipFile object at 0x0000026C91460750>], contents=('js/lib/babel-polyfill.min.js', 'js/lib/jquery/jquery.min.js', 'js/lib/modernizr.custom.js', 'js/lib/lodash.min.js', 'js/lib/sprintf.min.js', 'js/lib/knockout.js', 'js/lib/knockout.mapping-latest.js', 'js/lib/babel.js', 'js/lib/bootstrap/bootstrap.js', 'js/lib/bootstrap/bootstrap-modalmanager.js', 'js/lib/bootstrap/bootstrap-modal.js', 'js/lib/bootstrap/bootstrap-slider.js', 'js/lib/bootstrap/bootstrap-tabdrop.js', 'js/lib/jquery/jquery-ui.js', 'js/lib/jquery/jquery.flot.js', 'js/lib/jquery/jquery.flot.time.js', 'js/lib/jquery/jquery.flot.crosshair.js', 'js/lib/jquery/jquery.flot.resize.js', 'js/lib/jquery/jquery.iframe-transport.js', 'js/lib/jquery/jquery.fileupload.js', 'js/lib/jquery/jquery.slimscroll.min.js', 'js/lib/jquery/jquery.qrcode.min.js', 'js/lib/jquery/jquery.bootstrap.wizard.js', 'js/lib/pnotify/pnotify.core.min.js', 'js/lib/pnotify/pnotify.buttons.min.js', 'js/lib/pnotify/pnotify.callbacks.min.js', 'js/lib/pnotify/pnotify.confirm.min.js', 'js/lib/pnotify/pnotify.desktop.min.js', 'js/lib/pnotify/pnotify.history.min.js', 'js/lib/pnotify/pnotify.mobile.min.js', 'js/lib/pnotify/pnotify.nonblock.min.js', 'js/lib/pnotify/pnotify.reference.min.js', 'js/lib/pnotify/pnotify.tooltip.min.js', 'js/lib/pnotify/pnotify.maxheight.js', 'js/lib/moment-with-locales.min.js', 'js/lib/pusher.color.min.js', 'js/lib/detectmobilebrowser.js', 'js/lib/ua-parser.min.js', 'js/lib/md5.min.js', 'js/lib/bootstrap-slider-knockout-binding.js', 'js/lib/loglevel.min.js', 'js/lib/sockjs.min.js', 'js/lib/hls.js', 'js/lib/less.js')>, is empty
2023-11-01 16:03:48,171 - octoprint.server.preemptive_cache - INFO - ... done in 0.36s
2023-11-01 16:03:48,171 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://127.0.0.1:5000/', 'path': '/', 'query_string': 'l10n=en'}
2023-11-01 16:03:48,416 - octoprint - ERROR - Exception on / [GET]
- octoprint.server.preemptive_cache - INFO - ... done in 0.25s
- octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://127.0.0.1:8080/', 'path': '/', 'query_string': 'l10n=en'}
- octoprint.server.preemptive_cache - INFO - ... done in 0.27s
