Unable to connect to my cr-6 se printer with CF 6 Windows 10 Device manager sees com7 port for the printer when connected
tried specifing baud rate 9600 (as per device manager) did not work, auto detect did not work.
2021-05-15 18:36:14,953 - octoprint.util.comm - INFO - Serial detection: Could not open port COM7, baudrate 9600, skipping
2021-05-15 18:36:14,953 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error"
2021-05-15 18:36:14,953 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"
2021-05-15 18:36:14,957 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2021-05-15 18:36:24,333 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2021-05-15 18:36:24,334 - octoprint.util.comm - INFO - Connecting to port COM7, baudrate 9600
2021-05-15 18:36:24,345 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Error"
2021-05-15 18:36:24,345 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"
2021-05-15 18:36:24,345 - octoprint.util.comm - ERROR - Unexpected error while connecting to serial port COM7, baudrate 9600 from hook default: SerialException: 'Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31)' @ comm.py:_open_serial:3695
File "e:\octoprint\venv\lib\site-packages\octoprint\util\comm.py", line 3695, in _open_serial
serial_obj = factory(
File "e:\octoprint\venv\lib\site-packages\octoprint\util\comm.py", line 3677, in default
serial_obj.open()
File "e:\octoprint\venv\lib\site-packages\serial\serialwin32.py", line 80, in open
self._reconfigure_port()
File "e:\octoprint\venv\lib\site-packages\serial\serialwin32.py", line 222, in _reconfigure_port
raise SerialException(
serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: PermissionError(13, 'A device attached to the system is not functioning.', None, 31)
2021-05-15 18:36:24,350 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
