Windows Service Server Start and Stop , in loop
I'm using an old pc to be my Octoprint (Current version) server. The windows version is Tiny10 2303x86(Lightweight Windows 10)
The server service tries to open but close right away.
Can we run it on a 32bit Windows ? I can go with a 64 if need.
First , do you have a log files to see why ?
Reboot , restart the service
Windows save mode ?
Did you use my windows installer or the manual install instructions for setting up the services? My installer is only 64bit currently, and pretty sure it wouldn't even install for you so assume the manual installation instructions. Check octoprint.log for errors on startup.
I Used the Windows Installer .
I will check that tonight , thanks
the logs will be in the folder you used to install into, ie C:\OctoPrint\basedir\5000\logs\octoprint.log. There are also a couple of service logs that will show up in the installation folder, ie C:\OctoPrint\OctoPrintService5000.wrapper.log.
