Wired and Wireless at the same time
What is the problem? My router shows my PI is connected by wireless and wired. Is that a problem ?
What did you already try to solve it? Nothing, no idea what to do, seems to work correctly.
Logs (syslog, dmesg, ... no logs, no support) no logs
Hello @Dave_Cook !
No problem, a feature.
A router usually reminds former connections for some time. So you can see both.
If you connect the Pi via Ethernet cable to the router, this connection is preferred and WiFi is ignored.
Perfect ! Thanks !!
