Unable to ssh to RPI via wired connection. I get a connection refused error using IP address , wifi is NOT enabled. I do have an octopi instance already so I used the IP address instead of the .local address.
Reinstalled using Raspberry PI Installer twice
No logs available
macOS Monterey v12.0
RPI 3b+
Google Network box w/Eero
