Does any one successfully connected his Raspberry Pi running Octopi 0.17 to WPA-Enterprise WiFi network?
There is probably known bug at wpa-supplicant 2.8 which on this version has problem with connect with WPA-Enterprise authentication type network.
I've tried to follow the solutions proposed here, but I'm still not sucessfull.
