When sending a MMU file via OctoPrint, the wrong filament channel is being selected.
By sending via SD card - it works fine that way
OctoPrint 1.3.9 running on OctoPi 0.15.1
Here are parts of the log file and GCode file.
Serial log...
2018-11-04 10:23:08,002 - Send: N52 M117 ETA 13 38 06 Day 04*20
2018-11-04 10:23:08,010 - Recv: ok
2018-11-04 10:23:08,022 - Send: N53 M403 E0 F0*17
2018-11-04 10:23:08,029 - Send: N54 M403 E1 F0*23
2018-11-04 10:23:08,033 - Recv: MMU <= 'F0 0'
2018-11-04 10:23:08,258 - Recv: ok
2018-11-04 10:23:08,269 - Send: N55 M403 E2 F0*21
2018-11-04 10:23:08,274 - Recv: MMU <= 'F1 0'
2018-11-04 10:23:08,390 - Recv: ok
2018-11-04 10:23:08,400 - Send: N56 M403 E3 F0*23
2018-11-04 10:23:08,401 - Recv: MMU <= 'F2 0'
2018-11-04 10:23:08,491 - Recv: ok
2018-11-04 10:23:08,503 - Send: N57 M403 E4 F0*17
2018-11-04 10:23:08,505 - Recv: MMU <= 'F3 0'
2018-11-04 10:23:08,594 - Recv: ok
2018-11-04 10:23:08,601 - Send: N58 G1 Y-3.0 F1000.0*21
2018-11-04 10:23:08,605 - Recv: MMU <= 'F4 0'
2018-11-04 10:23:08,697 - Recv: ok
2018-11-04 10:23:08,704 - Send: N59 G1 Z0.4 F1000.0*61
2018-11-04 10:23:08,711 - Recv: ok
2018-11-04 10:23:08,721 - Send: N60 T0*12
2018-11-04 10:23:08,728 - Recv: ok
2018-11-04 10:23:08,735 - Send: N61 G1 X55.0 E32.0 F1073.0*126
2018-11-04 10:23:10,921 - Recv: echo:busy: processing
2018-11-04 10:23:12,993 - Recv: echo:busy: processing
2018-11-04 10:23:15,091 - Recv: echo:busy: processing
2018-11-04 10:23:17,212 - Recv: echo:busy: processing
2018-11-04 10:23:19,305 - Recv: echo:busy: processing
2018-11-04 10:23:21,370 - Recv: echo:busy: processing
2018-11-04 10:23:23,467 - Recv: echo:busy: processing
2018-11-04 10:23:25,540 - Recv: echo:busy: processing
2018-11-04 10:23:25,977 - Changing monitoring state from "Printing" to "Cancelling"
And the corresponding gcode lines...
; Send the filament type to the MMU2.0 unit.
; E stands for extruder number, F stands for filament type (0: default; 1:flex; 2: PVA)
M403 E0 F0
M403 E1 F0
M403 E2 F0
M403 E3 F0
M403 E4 F0
;go outside print area
G1 Y-3.0 F1000.0
G1 Z0.4 F1000.0
; select extruder
T0
; initial load
On the display, the filament shows changing from F1 to F2. Since it was already on F1 (T0), it should not need to change. The one thing that stands out to me is this...
There is no response to the first M403 command.
MK3_Doors_0.15mm_ABS_MK3MMU2.gcode (2.6 MB)
serial (1).log (25.4 KB)
