Wyze V2 - using latest webcam firmware
I cannot get the stream to show up in Octoprint
Reflashed the webcam back to stock firmware, then back to the webcam firmware
Reflashed the octopi instal from scratch
I don't know how to access the logs
Octoprint 1.4.0
OctoPi 0.17.0
On Raspberry Pi 4B Rev1.2 (2 gig)
No plugins have been installed since the refresh
Using a USB A-A cable https://www.cableleader.com/3ft-usb-3-0-a-male-to-a-male-cable-black.html
The Stream test shows a blank screen.
I followed the directions to edit octopi.txt using Atom
Terminal on the Pi responds to lsusb with:
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
I am pretty sure the camera is the Via Labs.
Basically I am out of idea, and can't figure out what's going on.
