Wyze Cam Pan
Loaded the Openmiko firmware + the wifi config. I'm able to SSH into the webcam successfully, but neither the snapshot nor the stream urls are server up any images. According to the various logs, its definitely doing things... I haven't directly plugged it into the PI as I assumed it would serve this wirelessly. Is that not true?
I've tried reloading the firmware and also copying the wpa wifi conf to the local storage instead of leaving it on the SD card.
Dec 9 18:35:00 openmiko cron.info crond[118]: wakeup dt=60
Dec 9 18:35:00 openmiko cron.info crond[118]: file root:
Dec 9 18:35:00 openmiko cron.info crond[118]: line /usr/sbin/logrotate /etc/logrotate.conf
Dec 9 18:35:04 openmiko local1.notice videocapture[336]: 1921107184: Current FPS: 25.00 / Channel 1
Dec 9 18:35:07 openmiko local1.notice videocapture[336]: 1923204336: Current FPS: 25.00 / Channel 0
Dec 9 18:35:13 openmiko local1.notice videocapture[336]: 1921107184: Current FPS: 25.00 / Channel 1
Dec 9 18:35:15 openmiko local1.notice videocapture[336]: 1923204336: Current FPS: 25.00 / Channel 0
Dec 9 18:35:21 openmiko local1.notice videocapture[336]: 1921107184: Current FPS: 25.00 / Channel 1
Dec 9 18:35:23 openmiko local1.notice videocapture[336]: 1923204336: Current FPS: 25.00 / Channel 0
OctoPrint Version 1.6.1
OctoPi Version 0.17.0
