When using the autohome function, x home and y home in octoprint the limit trigger switch is ignored carriage smashed into the frame.
All my print jobs start with an auto home command but now the carriage smashes into the trigger and I get a home error. The autohome function does work from the printers menu.
Tested the wire and switch with the multimeter both work fine.
Tested if the x move to the to the switch would also surpass the limit, it did not. (iphone app)
Tested just x home, it ignored the switch and crashed.
Tested the home function of the printer itself, that works fine.
read a thread about the absence of an sd card could trigger this bug. inserted a formatted sd card, confirmed it could be read. did not fix the problem.
rand a m119 command, even though manually triggering the triggers myself, the m119 reply remained "open" confirming the trigger is ignored by octoprint.
(Even-though I made a completely custom controlerbox case for my cr-10s the current configuration and firmware did work before the case mod.)
no
dont know.
System Information
Please copy/paste the following when requesting support on the forums or when opening a new bug report:
browser.user_agent : Mozilla/5.0 (Macintosh; Intel Mac OS X 10_14_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.93 Safari/537.36
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 1200
env.hardware.ram : 917016576
env.os.bits : 32
env.os.id : linux
env.os.platform : linux2
env.plugins.pi_support.model : Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version : 0.15.1
env.plugins.pi_support.throttle_state : 0x50000
env.python.pip : 20.3.3
env.python.version : 2.7.13
env.python.virtualenv : true
octoprint.safe_mode : false
octoprint.version : 1.6.0
printer.firmware : Marlin TH3D U1.R2.B5
systeminfo.generator : systemapi
Version 1.6.0, cr10s custom controlbox case Chrome, OSX mojave, 4 relay switch to for safety with psu control plugin.
