My xy axes are wrong. So when i setup the part in Cura i have to mirror it and rotate it 90 degree on the Z axis for it to print like it shows on the Cura screen. I have set the home on octopi to be upper left.
So how do i change the Y to become the X axis and also invert the x or y axis?
My printer is a CR-10S and both octopi and cura are the latest versions.
Not to mention that the invert mode of the Y axis, for example, needs to be the same in both your Cura printer profile and your OctoPrint printer profile.
Does the printer work right if you don't print via OctoPrint? (If you've never printed before OctoPrint then it's entirely possible that the X and Y cabling is swapped on your printer itself.)
Ok, lol, it is my fault. When i did put together the printer i had it turned 90 degree, so i was tired and put the y on the x axis. Fck i feel stupid now, goodnight.
