Can’t WiFi connect
I logged in my pi not my router
Try connecting an Ethernet cable to the Pi so that you can remote into it using ssh. Then run ifconfig to see what's going on with the wlan0 device. It's likely missing the word RUNNING in the flags. This would simply mean that your wifi router didn't allow it to connect to your network.
Then troubleshoot the Pi's /boot/octopi-wpa-supplicant.txt file to fix it.
Thank you for the help first. So i didn't understand you say the flag RUNNING where exactly.
ifconfig wlan say nothing.
But i make it to run.
With nano octopi-wpa.... i looked the file and have
2 configuration off the same thing. SSID=imac .....
and other was SSID=IMac the second was the right one. And was bad the country i had change it i dont know why. Thank You again.
This flag means that the router likes your wifi adapter and your attempt at connecting via wifi, for what it's worth.
wlan0: flags=4163<UP,BROADCAST,--->RUNNING<---,MULTICAST> mtu 1500
ether dc:a6:32:80:48:ad txqueuelen 1000 (Ethernet)
RX packets 5801 bytes 974976 (952.1 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 4980 bytes 1225181 (1.1 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
