Y-Direction Layer Shift
Sometimes when printing (usually with longer prints) I will get a layer shift in the Y-direction. This occurs at random layer heights.
Changed my cable connecting my Pi to my printer. I am now using a cable the supports data transfer and has ferric cores.
octoprint-systeminfo-20220913233902.zip (576.7 KB)
I am running Octoprint version 1.8.2 on my Raspberry Pi 4. The Pi is connected to my Ender 3 Pro via a cable for data transfer that has ferric cores at each end. I am using Cura 5.1.0 to slice my models and sending GCODE to the Pi via the print with octoprint plugin. Occasional and so far only with longer prints I have gotten a layer shift. This does not seem to be anything printer related but more file related or reading/interpreting the data.
Hello @MongoMaker !
If this occurs after a certain time of printing, then you may check the motor current and the proper cooling of the stepper drivers. (In this case for the Y-axis)
