When accessing Octoprint the browser displays "Forbidden
You don't have permission to access / on this server."
Restarted the Raspberry Pi.
Shutdown OctoPrint then restarted in safe mode.
Yes. It did not.
Complete Logs
pi@octopi : ~/.octoprint/logs $ ~/oprint/bin/octoprint serve --safe
2020-11-30 22:54:55,629 - octoprint.startup - INFO - ******************************************************************************
2020-11-30 22:54:55,632 - octoprint.startup - INFO - Starting OctoPrint 1.5.0
2020-11-30 22:54:55,633 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2020-11-30 22:54:55,633 - octoprint.startup - INFO - Reason for safe mode: command line flag
2020-11-30 22:54:55,635 - octoprint.startup - INFO - ******************************************************************************
2020-11-30 22:54:55,776 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2020-11-30 22:54:55,813 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-11-30 22:54:55,813 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-11-30 22:54:55,814 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-11-30 22:54:56,572 - octoprint.startup - INFO - Blacklist processing done, adding 10 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8)
2020-11-30 22:54:56,617 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-11-30 22:54:58,748 - octoprint.plugin.core - WARNING - Plugin Room Temperature Plugin (1.0) is blacklisted.
2020-11-30 22:54:59,380 - octoprint.plugin.core - INFO - Found 28 plugin(s) providing 17 mixin implementations, 34 hook handlers
2020-11-30 22:54:59,513 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-11-30 22:54:59,548 - octoprint.server - INFO - Intermediary server started
2020-11-30 22:54:59,599 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-11-30 22:55:00,229 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-11-30 22:55:00,236 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-11-30 22:55:00,238 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-11-30 22:55:00,241 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-11-30 22:55:00,244 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-11-30 22:55:00,247 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-11-30 22:55:00,250 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-11-30 22:55:00,253 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-11-30 22:55:00,256 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-11-30 22:55:00,260 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-11-30 22:55:00,262 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-11-30 22:55:00,265 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-11-30 22:55:00,267 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-11-30 22:55:00,270 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-11-30 22:55:00,272 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-11-30 22:55:00,274 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2020-11-30 22:55:00,897 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-11-30 22:55:03,042 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-11-30 22:55:05,104 - octoprint.util.pip - INFO - Version of pip is 9.0.3
2020-11-30 22:55:05,106 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-11-30 22:55:05,108 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-11-30 22:55:05,138 - octoprint.plugin.core - INFO - Initialized 17 plugin implementation(s)
2020-11-30 22:55:05,168 - octoprint.plugin.core - INFO - 28 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
| !Dashboard (1.16.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_dashboard
| !DisplayLayerProgress Plugin (1.24.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_DisplayLayerProgress
| !Enclosure Plugin (4.12) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_enclosure
| File Check (2020.8.7) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_file_check
| Firmware Check (2020.9.23) (bundled) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmware_check
| GCode Viewer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
| !GcodeEditor (0.2.9) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GcodeEditor
| !M117NavBar (0.1.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_M117NavBar
| !Preheat Button (0.5.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_preheat
| !Pushover (0.3.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_pushover
| #Room Temperature Plugin (1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_roomtemp
| !Simple Emergency Stop (1.0.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_simpleemergencystop
| !Tab Order (0.5.12) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_taborder
| !Terminal Commands (0.1.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_TerminalCommands
2020-11-30 22:55:05,218 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 917016576
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.15.1
| throttle_state: '0x0'
| python:
| pip: 9.0.3
| version: 2.7.13
| virtualenv: /home/pi/oprint
2020-11-30 22:55:05,235 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-11-30 22:55:05,237 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-11-30 22:55:06,838 - octoprint.server - INFO - Shutting down intermediary server...
2020-11-30 22:55:07,288 - octoprint.server - INFO - Intermediary server shut down
2020-11-30 22:55:07,293 - octoprint.events - INFO - Processing startup event, this is our first event
2020-11-30 22:55:07,298 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2020-11-30 22:55:07,301 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-11-30 22:55:07,310 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-11-30 22:55:07,329 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-11-30 22:55:07,388 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2020-11-30 22:55:07,386 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-11-30 22:55:07,390 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-11-30 22:55:08,340 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2020-11-30 22:55:08,525 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {u'throttled_mask': 0, u'throttled_voltage_now': False, u'throttled_voltage_past': False, u'throttled_overheat_now': False, u'throttled_now': False, u'throttled_past': False, u'throttled_overheat_past': False}
2020-11-30 22:55:09,374 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2020-11-30 22:55:09,672 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-11-30 22:55:09,908 - octoprint.server - INFO - Listening on http://0.0.0.0:5000 and http://[::]:5000
2020-11-30 22:55:10,065 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-11-30 22:55:10,174 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-11-30 22:55:12,606 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-11-30 22:55:12,619 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-11-30 22:55:12,625 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-11-30 22:55:13,170 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-11-30 22:55:13,174 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 5.2GB. That is considered sufficient for updating.
2020-11-30 22:55:14,064 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {u'python': '2.7.13', u'os': u'linux', u'ram': 917016576, u'octopi_version': u'0.15.1', u'version': u'1.5.0', u'pip': '9.0.3', u'cores': 4, u'freq': 1400.0, u'pi_model': u'Raspberry Pi 3 Model B Plus Rev 1.3', u'bits': 32}
2020-11-30 22:55:14,118 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.local/'}
2020-11-30 22:55:14,819 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {u'python': '2.7.13', u'os': u'linux', u'ram': 917016576, u'octopi_version': u'0.15.1', u'version': u'1.5.0', u'plugins': u'', u'pip': '9.0.3', u'cores': 4, u'freq': 1400.0, u'pi_model': u'Raspberry Pi 3 Model B Plus Rev 1.3', u'bits': 32}
2020-11-30 22:55:15,741 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 15}
2020-11-30 22:55:30,433 - octoprint.server.preemptive_cache - INFO - ... done in 16.32s
OctoPi: ?
OctoPrint: 1.5.0 - issue occurred immediately following in-app update from 1.4.2(?) to 1.5.0.
