Can you explain?
According your log, you connect via USB
2022-10-09 12:02:13,176 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Unsupported command - ooo
| Last lines in terminal:
| Changing monitoring state from "Offline" to "Detecting serial connection"
| Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
| Trying port /dev/ttyACM0, baudrate 115200
| Connecting to port /dev/ttyACM0, baudrate 115200
| Handshake attempt #1 with timeout 2.0s
| Connected to: Serial<id=0x6ce00f10, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
| Send: N0 M110 N0*125
| Recv: error:Unsupported command - ooo
A few lines alter:
2022-10-09 12:02:21,979 - octoprint.util.comm - WARNING - Received an error from the printer's firmware:
| Connected to: Serial<id=0x6cf89e70, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
| Recv: ok
| Changing monitoring state from "Detecting serial connection" to "Operational"
| Recv: ok
| Recv: ok
| Send: N1 M115*39
| Recv: FIRMWARE_NAME:Smoothieware, FIRMWARE_URL:http%3A//smoothieware.org, X-SOURCE_CODE_URL:https://github.com/Smoothieware/Smoothieware, FIRMWARE_VERSION:edge-2b84ffc, X-FIRMWARE_BUILD_DATE:Jul 3 2019 21:31:57, X-SYSTEM_CLOCK:100MHz, X-AXES:5, X-GRBL_MODE:0, X-CNC:0, X-MSD:0, X-WARNING:deprecated_MCU
| Recv: ok
| Send: M21
| Recv: !!
Another line was rejected.
You may check the quality of the USB connection.
There is also this message from the printer board:
| Recv: WARNING: This is not a sanctioned board and may be unreliable and even dangerous. This MCU is deprecated, and cannot guarantee proper function
