CR-10s Pro V2 with BLTouch (RPi3b+ and RPi4)
After printer completes autolevel (G29) it goes Home to the center of the bed, stops and checks home position and on the way to do the purge line on the left side of the bed, the hotend stops halfway and starts to rise. If I am not there watching it, it will raise as high as it can go and continues to try to rise vibrating at the top.
This just started happening in the last month after my older version of OctoPrint updated. I do not remember what version I was previously using, as I have updated Octoprint every time I get a notice to upgrade it.
I am currently using Cura 4.6.1 on a Windows 10 PC connecting to RPi with OctoPrint Version 1.4.2
I have tried using 2 different RPi's (RPi3b+ and RPi4) with the same installed version.
If I wipe the RPi clean and reload it with OctoPi, complete the setup again, it may work the first time and then goes back to lifting the Z-axis on the next print. I have done tis multiple times.
I uninstalled Cura 4.6.1 and reinstalled it.
I loaded the new version of Cura on a different PC, rebuilt the RPi's and tried printing from it and the printer does the same thing.
My last attempt, the printer completed the purge line and on the way back to start the print the nozzle dove into the bed destroying the glass bed and bending the hotend. I have not attempted to try using Octoprint since I repaired the printer.
If I save the file to the SD Card, the printer works perfectly.
Complete Logs
I did not have any logs enabled when the issue happened. The last time I tried using Octoprint it did a purge line and then crashed into the bed destroying my bed and bending my hotend. I have not used Octoprint since.
I am currently using Cura 4.6.1 on a Windows 10 PC connecting to RPi with OctoPrint Version 1.4.2 via MS Edge browser
