Hi there!
I switched back from Lerdge-K to SKR1.3 and have a big problem now.
My Sidewinder x1 has an additional second Z endstop and worked fine with the Lerdge Board.
Now i have switched back to SKR 1.3 and Marlin 2.0.5.3 for some reason and have a mystical problem with homing the Z axis.
WHAT NOT WORKS:
When i send the print over Octoprint(wifi) - and the gcode performs G28 after heating, the second Z Stepper with the second endstop will not stop when the second Z endstop is triggerd and the Z Axis crashs into the bed.
What works:
Home the Z Axis with the TFT Display in the Movement Menu
Home the Z Axis with the TFT Display in the Gcode Terminal with G28
Home the Z Axis with pronterface
Home the Z Axis with the any slicer controll
print over USB, SD Card
Home the Z Axis with Octoprint controll buttons works also fine!
Home the Z Axis with Octoprint termianl and G28 works also fine!
What have i tried to solve the Problem?
-new octoprint install
-checked my Marlin config
-tried several slicers (Prusaslicer + S3D)
-tried Xmax instead of Zmax for the second endstop microswitch.
-M119
-Marlin 2.0.5.3
-SKR1.3 with TMC2209 and TFT35
-Octoprint,latest 1.4.0
at this point, i'm out of ideas...
Cheers, Markus
Hello @MarkusN!
So, what gcode command is used to home the Z axis in the print file?
Maybe you have to reconfigure the startcode in the slicer.
Hi Ewald!
G28.
here the first lines from a Prusaslicer file:
https://pastebin.com/WemtXchv
here what Octoprint shows:
https://pastebin.com/zQkk4E2e
the startcode is stepwise reduced for bugfixing and now the only command is the G28
@Ewald_Ikemann, you need more information?
Sorry, I've been to work...
So, when the firmware accepts G28 from the terminal but not from inside a print file with line number and a checksum, I assume it maybe could be a fault inside marlin.
But you can try this:
Instead of just G28 in the start script, you may can try this
G28 X Y
G28 Z
(https://marlinfw.org/docs/gcode/G028.html)
Hi @Ewald_Ikemann!
i have tried that but have the same trouble with splitting the G28 .
Have you already consulted the marlin forums?
I haven't done that. Till now, i thought that's a Octo Problem
It works fine from the control tab and from the terminal.
Referring to the log you sent, G28 is properly sent to the printer.
Send: N5 G28*22
Recv: echo:busy: processing
And there the issue happens.
I seems the issue happens in the firmware.
@Ewald_Ikemann
right now I'm flashing bugfix. I will call back soon
@Ewald_Ikemann
unfortunately the same bug with marlin bugfix 2.0.x (April)
Printers with two Z endstops are not uncommon, I wonder that there are no more questions on the subject
So, does this also appear when you print from SD card or from pronterface?
@Ewald_Ikemann
Only when i print over Octoprint, it works fine with SD Card and USB Stick!
i use pronterface only for testing the hardware. Is it possible to send a print job with pronterface? I'll try that.
@Ewald_Ikemann
Ok, i have send the same print file with pronterface and that works fine! No problems with Pronterface
But from your log excerpts I can't see OctoPrint is doing something wrong.
I still recommend to ask a marlin forum about this. It's always better to seek on multiple sides.
Thanks for your help @Ewald_Ikemann!
