Z-Offset seems to change when using Octoprint
When printing from the SD card, all is well. Bed is level, z offset is set prints come out great. When I use octoprint the first layer is buried into the bed ruining the bed. When I try and use the SD card I have to go and modify the Z offset several times and eventually end up back at -2.86.
ordered a new printer but i still happens
no
tbd
octoprint-systeminfo-20230303141314.zip (25.2 KB)
Hello @Dan_Farmer !
Please do so.
Behold:
You have a power issue:
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
