What is the problem
I was wondering if there is a way of seeing the Z position (or XY) while motors are moved from the control tab. Other than counting presses I cant see another way to know the position. Wanted to check the physical limits on a DIY printer. Its only visible in the gCode viewer while actually printing. Thanks.
Complete Logs
