## Bug Description
I have been having an issue with the latest release version β¦of marlin 2.0 where a filament runout no longer sends the host action commands to Octoprint.
### My Configurations
[Marlin Config Files.zip](https://github.com/MarlinFirmware/Marlin/files/4738092/Marlin.Config.Files.zip)
[Octoprint_serial_Log.log](https://github.com/MarlinFirmware/Marlin/files/4738088/Octoprint_serial_Log.log)
### Steps to Reproduce
1. Configure #define FILAMENT_RUNOUT_SCRIPT "M600"
2. Start a 'streaming' print with Octoprint
2. Trigger a filament runout
**Expected behavior:** I expect FILAMENT_RUNOUT_SCRIPT "M600" to function the same as a manually entered M600 into the serial console.
All host action commands are sent:
2020-06-05 15:40:36,192 - Recv: ok
2020-06-05 15:40:36,196 - Changing monitoring state from "Printing" to "Pausing"
2020-06-05 15:40:36,208 - Send: N4140 M400*22
2020-06-05 15:40:36,448 - Recv: ok
2020-06-05 15:40:36,451 - Send: N4141 M600*21
2020-06-05 15:40:36,453 - Recv: //action:paused
2020-06-05 15:40:36,454 - Printer signalled that it paused, switching state...
2020-06-05 15:40:38,472 - Recv: echo:busy: processing
2020-06-05 15:40:43,796 - Recv: //action:notification Print Paused
2020-06-05 15:40:49,484 - Recv: echo:busy: processing
2020-06-05 15:41:00,947 - Recv: echo:Insert filament and press button
2020-06-05 15:41:00,965 - Recv: //action:prompt_end
2020-06-05 15:41:00,974 - Recv: //action:prompt_begin Nozzle Parked
2020-06-05 15:41:00,983 - Recv: //action:prompt_button Continue
2020-06-05 15:41:00,995 - Recv: //action:prompt_show
2020-06-05 15:41:01,483 - Recv: echo:busy: paused for user
2020-06-05 15:41:45,950 - Recv: echo:Press button to heat nozzle
2020-06-05 15:41:45,953 - Recv: //action:prompt_end
2020-06-05 15:41:45,961 - Recv: //action:prompt_begin HeaterTimeout
2020-06-05 15:41:45,968 - Recv: //action:prompt_button Reheat
2020-06-05 15:41:45,981 - Recv: //action:prompt_show
2020-06-05 15:41:47,485 - Recv: echo:busy: paused for user
2020-06-05 15:42:50,875 - Recv: //action:notification Print Paused
2020-06-05 15:42:50,885 - Recv: echo:Insert filament and press button
2020-06-05 15:42:50,889 - Recv: //action:prompt_end
2020-06-05 15:42:50,905 - Recv: //action:prompt_begin Reheat Done
2020-06-05 15:42:50,913 - Recv: //action:prompt_button Continue
2020-06-05 15:42:50,922 - Recv: //action:prompt_show
2020-06-05 15:42:51,487 - Recv: echo:busy: paused for user
2020-06-05 15:43:09,957 - Recv: //action:prompt_end
2020-06-05 15:43:09,968 - Recv: //action:prompt_begin Paused
2020-06-05 15:43:09,977 - Recv: //action:prompt_button PurgeMore
2020-06-05 15:43:09,987 - Recv: //action:prompt_button Continue
2020-06-05 15:43:09,998 - Recv: //action:prompt_show
2020-06-05 15:43:11,488 - Recv: echo:busy: processing
2020-06-05 15:43:27,628 - Recv: //action:prompt_end
2020-06-05 15:43:27,642 - Recv: //action:prompt_begin Paused
2020-06-05 15:43:27,654 - Recv: //action:prompt_button PurgeMore
2020-06-05 15:43:27,662 - Recv: //action:prompt_button Continue
2020-06-05 15:43:27,671 - Recv: //action:prompt_show
2020-06-05 15:43:29,488 - Recv: echo:busy: paused for user
2020-06-05 15:43:37,492 - Recv: echo:busy: processing
2020-06-05 15:43:38,354 - Recv: //action:resumed
2020-06-05 15:43:38,358 - Printer signalled that it resumed, switching state...
2020-06-05 15:43:38,362 - Changing monitoring state from "Pausing" to "Resuming"
2020-06-05 15:43:38,438 - Recv: //action:notification Printing...
2020-06-05 15:43:38,450 - Recv: ok
2020-06-05 15:43:38,458 - Send: N4142 M114*20
**Actual behavior:** [What actually happens]
Filament runout sensor is triggered, the host commands are only partially sent, no pause command nor resume command are sent to the host. In this case octoprint will get stuck in a communication timeout trying to send the next set of GCODE until the filament is changed:
2020-06-05 15:27:23,388 - Recv: ok
2020-06-05 15:27:23,395 - Send: N1924 G1 F2400 X104.186 Y94.262 E212.06936*6
2020-06-05 15:27:23,462 - Recv: T:205.00 /205.00 B:18.59 /0.00 @:87 B@:0
2020-06-05 15:27:23,481 - Recv: //action:prompt_end
2020-06-05 15:27:23,490 - Recv: //action:prompt_begin FilamentRunout T0
2020-06-05 15:27:23,500 - Recv: //action:prompt_show
2020-06-05 15:27:23,513 - Recv: //action:paused filament_runout 0
2020-06-05 15:27:25,019 - Recv: ok
2020-06-05 15:27:25,041 - Send: N1925 G1 X123.506 Y94.262 E213.15363*103
2020-06-05 15:27:25,467 - Recv: T:205.00 /205.00 B:18.59 /0.00 @:81 B@:0
2020-06-05 15:27:27,467 - Recv: T:205.00 /205.00 B:18.75 /0.00 @:82 B@:0
2020-06-05 15:27:29,467 - Recv: T:204.82 /205.00 B:18.59 /0.00 @:100 B@:0
2020-06-05 15:27:29,489 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-06-05 15:27:29,501 - Send: N1926 M105*27
2020-06-05 15:27:31,467 - Recv: T:205.00 /205.00 B:18.59 /0.00 @:95 B@:0
2020-06-05 15:27:33,488 - Recv: T:205.54 /205.00 B:18.75 /0.00 @:60 B@:0
2020-06-05 15:27:33,505 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-06-05 15:27:33,516 - Send: N1927 M105*26
#### Additional Information
I change value of host_action_paused(false) to host_action_paused(true) in the runout.cpp and now I receive the correct //action:paused command before the M600 is run, but I still do not receive the resume command or any of the other host action prompts. This is a bit better but requires me to manually 'resume' the print from Octoprint post filament change.
**runout.cpp**
```javascript
#if ENABLED(HOST_ACTION_COMMANDS)
if (run_runout_script
&& ( strstr(FILAMENT_RUNOUT_SCRIPT, "M600")
|| strstr(FILAMENT_RUNOUT_SCRIPT, "M125")
#if ENABLED(ADVANCED_PAUSE_FEATURE)
|| strstr(FILAMENT_RUNOUT_SCRIPT, "M25")
#endif
host_action_paused(true); //******changed this*****
else {
// Legacy Repetier command for use until newer version supports standard dialog
// To be removed later when pause command also triggers dialog
#ifdef ACTION_ON_FILAMENT_RUNOUT
host_action(PSTR(ACTION_ON_FILAMENT_RUNOUT " T"), false);
SERIAL_CHAR(tool);
SERIAL_EOL();
#endif
host_action_pause(false);
SERIAL_ECHOPGM(" " ACTION_REASON_ON_FILAMENT_RUNOUT " ");
SERIAL_CHAR(tool);
SERIAL_EOL();
#endif // HOST_ACTION_COMMANDS
