As the title suggests, I updated my Octoprint to 1.3.11 and now it does not work with my Maker Select.
Basically what happens is I start the print job, then it moves to Origin to begin, and then it sits there doing nothing.
I've tried to roll back the firmware to 1.3.10 but now that problem has followed it back to .10
I've tried safe mode, which straight up doesn't connect to the printer. Included a log about that below.
OctoPrint version:1.3.11
OctoPi version: 0.16
printer: Maker Select v2
firmware: Not sure.
I'm at a total loss. Was hoping that rolling back the update would fix it for the moment, but I need help. I love Octoprint and would love to continue using it instead of the SD card.
Any help you can provide is well appreciated. Thank you!
I'm using Cura 3.5 atm, and a profile chosen originally for the WanHao Di3 which my MP Maker Select v2 is a direct clone of. Before that I was using a Prusa i3 profile that was working just fine through octoprint. I did switch to the Wanhao profile fairly recently, around the same time as I updated Octoprint. Could be related!
I'll have to check that and perhaps try the latest version of Cura.
Different slicers have a different syntax for "variables" in the start code that should be replaced with a value that usually will be set/changed in the GUI. Cura uses {variable}, Simplify3D uses [variable] and some others (I don't remember their names) use <variable>.
Printer profiles get passed around fairly often and moving a profile from one slicer to another requires some care to get the syntax correct in the start gcode and end gcode. Double check the start gcode and end gcode in the slicer you are using to make sure you haven't fallen victim to this.
Cura is a good slicer and Ultimaker keeps making it better and better. I think you will like 4.0 (or 4.1 if you are daring).
Cura was started by Europeans who have a noun + adjective grammar ordering in their native language. So at one time it was travel_speed and then got changed to speed_travel. Edit it in Cura's settings to whatever ordering it currently isn't.
The assumption here is that this is sliced with a recent version of Cura. It's possible that this file was sliced several versions ago. Just make it work, would be the advice.
This has nothing to do with the setting key. When Cura was rewritten from scratch, it was decided to standardize the setting names on "category"_"setting name". This convention is not true for all settings by the way. Best is just to look them up here: http://files.fieldofview.com/cura/Replacement_Patterns.html
It was the printer profile. When I use a modified Prusa i3 profile it works just fine! The Wanhao Dup i3 profile does not work when translated through Octoprint
