If you see something like this in the terminal tab, possibly in form of an endless loop:
Send: N18 G1 F{travel_speed}*81
Recv: Error:Format error
Recv:
Recv: Resend:18
or - starting with OctoPrint 1.4.1 - you get a notification like this after uploading a GCODE file:
you are either not using Cura to slice or are using {travel_speed} instead of {speed_travel} as a placeholder for the travel speed in your start/stop GCODE scripts in your slicer.
Older versions of Cura used to use the former, then some versions later this was changed to the latter and since then people copying code meant for older versions into newer ones have been running into this issue and it doesn't seem to die.
Just replace all occurrences of {travel_speed} with {speed_travel} and reslice your files.
