After Z-homing interruption, octoprint can't connect to printer
Printer was z-homing with a crtouch, I reached for the nozzle to clear some loose filament fibers hanging off of it. In doing so, my hand bumped the crtouch probe so it stopped, then went for the slow press to verify. I stopped the print and the printer gave a "fail to home" error and requested a restart. After restarting, octoprint now "could not autodetect your printer" and "no serial port found"
The state of the printer on the octoprint server reads: "No more candidates to test, and no working port/baudrate combination detected."
Restarted printer again.
Restarted octoprint.
Unplugged and plugged back in the printer to the raspberry pi.
Rebooted the raspberry pi.
Yes
octoprint-systeminfo-20230809202335.zip (1.1 MB)
Octoprint 1.9.2
Octopi 0.18.0 on Raspberry pi 4
Ender 3 V2 with Jyers firmware
When you restart the printer, does it give a message on it's display?
Have you checked the CRTouch?
Nope, printer works fine on its own. CRTouch works fine as well.
Even if it ran before, but because it is a Creality printer try:
Tried it with and without the sd card, same result.
Also already had tape on the 5v pin so no luck there either
Looks like swapping my cord to the printer fixed it, not sure how but it did.
